Toonaway
Dec 30, 2016Guide
R7800 - Unable to login to OpenDNS / Parental Controls
I have followed the various support instructions but have failed to get Genie to log into OpenDNS. I receive the following: There was an error signing in, please make sure you're connected to the I...
IndianaMark
Feb 02, 2017Aspirant
Good luck. I believe it's a firmware issue. After you rolled back the firmware to 12, did you use a paper clip and reset it to factory settings and then use the setup wizard?
