Toonaway
Dec 30, 2016Guide
R7800 - Unable to login to OpenDNS / Parental Controls
I have followed the various support instructions but have failed to get Genie to log into OpenDNS. I receive the following: There was an error signing in, please make sure you're connected to the I...
HJA
May 08, 2017Aspirant
Hello All,
I'm also the victim of this same problem. And revieweing all the previous comments, I cannot agree with you all that how bad it is for a Company like Netgear, to linger upon this problem and not finding a genuine solution to this problem.
Just to add, I had also bought router R7800 in April 2017 and now facing the same problem.
Please share any permanent solution if anyone has found so far.
Thanks
