Maddman's avatar
Maddman
Follower
Apr 12, 2020
r7900p can't find where to put the activation code
just brought it. the e-mail tell me to;
1. Sign into your NETGEAR Armor account.
2. Go to My Subscriptions, then click or tap on “Activation code”
For security reasons, you might be required to authenticate again when you access My Subscriptions.
3. Next, copy and paste this activation code: T2UQGLJWZ6
4. Press Enter and wait until your activation code is validated.
i have gone to nighthawk app and open it, not a thing. try the security on home and opening sceen, still cannot find it. where to i go??
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Maddman,
    May you perform a factory reset on the router by pressing down on the reset button for 15+ seconds. After successfully resetting the router, you will need to run through the setup assistant again and you may use the Nighthawk app to complete the setup. Once the router is up and running, please refer to the article linked below on how to activate Armor using the Nighthawk app.
    https://kb.netgear.com/000059442/How-do-I-activate-NETGEAR-Armor-using-the-Nighthawk-app
    Christian
