FloridaRob
Jun 11, 2019Tutor
R7900P Shows as "Disconnected" in Nighthawk App
Need to login to admin on my R7900P remotely. Nighthawk App states Router is disconnected, but it isn't. I can login to the internet router the R7900P is connected to (in bridge mode) and ping test the Nighthawk, and it returns and passes tests. It is also broadcasting a WiFi network using the default (!!!!) settings. I can remotely cycle power to the R7900P and have done so, which makes no difference.
Mac OS desktop Netgear Genie (on desktop) won't allow me to log in to anything remotely, the option simply doesn't display on the appropriate page. It does show on my laptop, go figure, but the particular router I need to admin shows as being unavailable in the menu for remote administration.
Why does the Nighthawk App say that the router is disconnected when it is not?
Don't anyone tell me to update firmware on the router because I am 4000 km away in another country, which is the whole reason I setup remote administration on the device in the first place, and yes... I did set it up when the router was installed, and reset up just two months ago. The whole purpose in having remote admininstration setup is so that the router can be administered REMOTELY. Going on site is not an option or a solution. If I was onsite I wouldn't need remote administration.
I am extremely frustrated by how buggy NetGear Genie was when I first set it up. It apparently couldn't handle accessing two different R7900Ps in two different locations. I had remote administration setup and working on this router A through Netgear Genie before I left the site, but router B wasn't able to be accessed remotely. I called NetGear support and they couldn't fix the problem, heck they couldn't even understand the problem (it would help if tech support offered in English was provided by people who can speak English), and I ran out of time and had to leave the country. Now I have been instructed through NetGear to install the Nighthawk App on my phone, which I have, and low and behold router B appears and is accessible, and router A says "Disconnected", which it isn't. In NetGear genie which works (somewhat) on my laptop, now Router B can be accessed but Router A can not be (reads 'unavailable'), the opposite of when I was onsite.
In the meantime, without the problem of NEVER being able to access both Routers through either app at the same time ever being resolved, even after wasting HOURS with useless technical support which never solved the problem, my support has expired.
I am offered more "support" at a cost nearly equal to one of the routers, but it couldn't/wouldn't solve the problem before, why would I buy something which has proven to not work time and time again?
Has anyone had a R7900P showing as 'disconnected' in the Nighthawk App and been able to establish a connection with it without being on site?
If firmware needs to be upgraded to connect to it, can this be done without being on site, and when the R7900P shows as disconnected?
Again, the R7900P is NOT disconnected, it is pingable and working, so there is a fault/bug problem with NetGear software somewhere along the line, and this should have been fixed during my support period but never was. Now I have a customer screaming at me over WiFi access. Can anyone assist?
Many thanks in advance.
- XiaoweiAspirant
Same problem here with R7900P. Can anyone help?
FloridaRob wrote:Need to login to admin on my R7900P remotely. Nighthawk App states Router is disconnected, but it isn't. I can login to the internet router the R7900P is connected to (in bridge mode) and ping test the Nighthawk, and it returns and passes tests.
Ok, I'm more than confused:
Your Internet "router in bridge mode" has a public IP address so it can be reached from the wild Internet?
What IP address are you using to ping the R7900P?
Or does the R7900P run in bridge (Access Point) mode at the end of the day?
Afraid, something reads wrong for me ....
FloridaRob wrote:Mac OS desktop Netgear Genie (on desktop) won't allow me to log in to anything remotely, the option simply doesn't display on the appropriate page. It does show on my laptop, go figure, but the particular router I need to admin shows as being unavailable in the menu for remote administration.
What the Nighthawk App and the Genie desktop programs show (at least one of the two) indicates that the router is disconnected from the Netgear cloud, where the Nighthawk App as well as the Genie desktop are connecting to.
Was travelling with some LTE modem and a NEtgear router the last two weeks, and randomply when trying to check the set-up beyond of the WiFi reach I've seen the "Disconnected" listing on the App remote access list. Minutes later it was back. And no obvious problem or Internet disconnection on the router itself. Oh well....
Is it possible this router did one of these unexpected factory resets some Nighthawk are hit by from time to time, or are there obvious config options which were retained (beyond of the default SSIDs)?
What I've experienced with the desktop Genie on both MacOS and Windows is that it sometimes seem to stick to a "local" login attempt, and it's tricky or kinda impossible to change the mode to remote.
schumaku wrote:
Ok, I'm more than confused:Your Internet "router in bridge mode" has a public IP address so it can be reached from the wild Internet?
I may be using wrong terminology. I use the R7900P as an access point to create a WiFi network in my vacation home for my guests to access the internet, in order to islolate them from the 'actual' router/internet access point, which is the router supplied by my ISP. I have remote administration setup on both the first router, and the R7900P. So I can login to the first router with my admin credentials, and see the entire LAN and its settings. While logged into the original router, I can see the R7900P and its ethernet connection to the original router. I can ping it from the original router, to test the connection, and confirm that it is there, on and responding. I also have guests at the vacation rental who tell me that they can see the original WiFi default network SSID broadcast by the R7900P, and login to it with the default credentials.
So it is not 'disconnected'. It is there, on the local network, and so can be reached. I can even open up ports for it if necessary.
schumaku wrote: What the Nighthawk App and the Genie desktop programs show (at least one of the two) indicates that the router is disconnected from the Netgear cloud, where the Nighthawk App as well as the Genie desktop are connecting to.All well and good, but your statement doesn't explain WHY it is disconnected. There is no 'reason or excuse' for this.
schumaku wrote: Was travelling with some LTE modem and a NEtgear router the last two weeks, and randomply when trying to check the set-up beyond of the WiFi reach I've seen the "Disconnected" listing on the App remote access list. Minutes later it was back. And no obvious problem or Internet disconnection on the router itself. Oh well....
Is it possible this router did one of these unexpected factory resets some Nighthawk are hit by from time to time, or are there obvious config options which were retained (beyond of the default SSIDs)?No obvious problems... (like so many internet issues when they occur) but "Oh well..." is not really an answer. The Motorola router supplied by my ISP has never lost its programming though countless power failures and surges, in ten years of operation. So a shoulder shrug is not really an answer. It means no solution, and this apparent hunk of junk I was sold is not up to the task of doing what the manufacturers purport it is capable of doing.
And it appears that the router has been completely reset to factory default settings. This is unacceptable performance. A simple failure of the device to do what it is supposed to do. And without any reasonable technical support on the part of the supplier to provide a solution.
schumaku wrote: What I've experienced with the desktop Genie on both MacOS and Windows is that it sometimes seem to stick to a "local" login attempt, and it's tricky or kinda impossible to change the mode to remote.
Which describes what I have run into. Which is basically saying "Yes, I've experienced the same problems you have." Thank you. I appreciate your interest, but it moves neither of us closer to a solution.
The fact that NetGear Genie gets 'stuck' is just a reflection of bad programming, nothing else. Testing and user experience must have already revealed this issue many times over. Was the problem fixed and a newer version released? No. The software is now discontinued without a replacement. I don't want a mobile solution. I want a desktop app that works like the box said I was getting with the router I bought.
Obviously I'm not alone.
Again, I appreciate your interest, and the last thing I want to do is to appear rude, but I see no movement towards a solution here. It is all well and good for Netgear to setup a 'community', but what for? So their customers can provide customer support for them? I would love some assistance with these issues, but I don't really believe there are any solutions. No one from Netgear has responded.
Thank you very much for your time and interest in my case! :)
FloridaRob hope you understand that you talk to communiy members, I'm in not working or helping people here on behalf of Netgear.
FloridaRob wrote:I use the R7900P as an access point to create a WiFi network ...
That's the point: When I have it right, this a limitation of the Nighthawk App vs Nighthawk routers in AP mode.
Or would you like to state that the Remote Management was available and workable, showing the AP in the App Remote Access list, and allowing management?
