ChettyM
Feb 06, 2022Initiate
R8000P firmware issue
I installed the latest firware about a month or two ago and I have been having problems that the site can't be reached etc.,
on all browsers. I tried flushing the DNS and cleaning up history etc., I spent lot of time and nothing helped. Finally I spent over 4 hours with tech support and nothing worked until we resorted to previous version. So far, this seemed to work. Clearly there is a bug in the new firmware version.
They charged me for this support call with an annual support contract. I need to call customer service to request a refund.
Support isn't free unless you're in your first 90 days of purchase. And the hardware wasn't defective (or it wouldn't have booted) which the warranty would cover.
You can try requesting a refund.
Its always worth a shot.
Next time I'd recommend posting on here before going to support as its free on here and thats a known issue with that firmware.
We usually have people start by enabling IPv6.
If that doesn't work, then we recommend the downgrade.
- ChettyMInitiateNetgear should let you know to revert back to Previous version and not let people wander to find solutions. It costed me lot more on booking airline tickets as this bug popped and blocked buying tickets at the last minute. I had to try again and pay more expensive tickets for two.
ChettyM wrote:
Netgear should let you know to revert back to Previous version and not let people wander to find solutions.It is in the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual on updating the firmware.But you are right. They should make it easier to find the details:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
You are not wrong there.
Search - NETGEAR Communities – R8000P
