Draketungsten's avatar
Jul 31, 2023
RAX54S - Access Control
When I log in to my Rax54 and go to the Access Control function, it tells me that I have to use the Nighthawk App.  When I got to the Nighthawk App, it doesn't give me the control I'm looking for.  I want the granular control that the Web GUI use to give me,  Deny all new MACs.  Or at the very least all new MACs added to a default access group.
Completely reset the router and still getting the same result.  Firmware and app are up-to-date.
Anyone else running in to this?
1 Reply
  • FURRYe38's avatar
    I don't think the web ui nor NH app support that. You can either enable or disable or block devices by device select only.
