PD72
Nov 20, 2017Follower
Loss of internet after enabling Circle by Disney on R7000
I enabled Circle by Disney on the R7000 but then started experiencing internet dropouts. I have rebooted the router and the problem goes away for about an hour before dropping the internet again. ...
dennisjm
Apr 30, 2018Tutor
I just had my first incident of having to disable then re-enable Circle after serveral days of usage. Symptoms are some websites still work and others stop working.
Cause is that DNS resolution stops working.
We just got this router for the soul purpose of having some parental controls and Circle seemed like a good choice but I can't say impressed with it so far. Features are OK but if I have to restart it every few days I'm going to have to come up with something else.
Circle info:
Agent Version: 2.0.8.0
App Database Version: 1.2.4
Router Version: V1.3.1.26_10.1.3
R7000P AC2300 Nighthawk
juched
Apr 30, 2018Apprentice
Do you have IPv6 enabled? Try turning it off. That made it stable for me.
Circle doesnt support IPv6 anyways, i have switched to a real circle device and it just down converts IPv6 requests to IPv4 ones anyways.
- dennisjmApr 30, 2018Tutor
I"m afraid no, ipv6 hasn't ever been enabled.
- dennisjmMay 02, 2018Tutor
Here we are a couple days later. Time's up for stable use. Had to turn circle off then back on again. Same problem. DNS resolutions stops working.
- amoreyOct 23, 2018Initiate
I have similiar issues since enabling Circle.
I have tried Circle in the past and had grief.
Need to enable again to control the kids access and unhappy to report that previous issues still exist.
- dennisjmOct 23, 2018Tutor
I haven't had the issue "yet" on the latest firmware. Been running V1.3.1.44_10.1.23 for a week or so.
Before that I was able to run a previous version of the firmware without issue.
1.3.0.20 -> I ran this for a number of months without issue.
1.3.1.26 -> is the version that kept needing a reboot to restore internet activity w/ circle enabled.
- BeykeysrJan 11, 2019AspirantHave you been having good luck after using the separate circle device?
- hijikJan 14, 2019Aspirant
we use the feature which is imbedded into the router -not a seperate device
