vicntc
Nov 23, 2025Aspirant
Nighthawk App (Android) timeout
Hello, I have a Netgear R7000 which works perfectly fine and is accessible via web browser from my laptop. Unfortunately, I can't seem to use the Nighthawk app. It gets as far as the "Login r...
Nov 23, 2025Guru - Experienced User
What modem/gateway is it connected to? Sometimes double nats cause issues with the app.
Are you using any ad blocking services like unbound or pihole? Or DNS servers?
