Resmithn
Oct 23, 2017Tutor
ReadyShare Vault Service will not run
Installed Windows 10 Fall Update. ReadyShare Vault service [GenieTimelineService.exe] will not run. Faulting module is GSWatcher4.dll. Have another PC [w/o Windows Fall Update] ReadyShare Vault runn...
Resmithn
Oct 30, 2017Tutor
Netgear support was awful. They wanted $150 since the "90 days" expired. Submitted to Genie9, their reply is below.
New reply for the ticket #GTLSup00181350
Hello Robert,
Regarding your issue, we're well aware of this problem as it has been caused by the latest update of Windows 10. Unfortunately we couldn't solve the issue on the 2016 version. However, our 2017 doesn't have this problem and it can be downloaded from the following link :
http://www.genie9.com/business/Genie_Timeline_pro/download.aspx
If you wish to purchase it, please note that we're running a 50% discount which can be claimed from the following link :
http://www.genie9.com/promo/Genie9OffersHalloween.aspx?utm_source=halloween_offer&utm_medium=genie9_email&utm_campaign=23_10_2017
Thomas Parker
Genie9 Technical support team
Genie9, Backup redefined
#GTLSup00181350
Thomas Parker
#GTLSup00181350
- DexterJBNov 14, 2017NETGEAR Moderator
Hi Resmithn,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- ResmithnNov 14, 2017Tutor
No, as said I downloaded Genie Timeline per thread above. ReadyShareVault will not run on PC with Windows Fall update installed.
- DexterJBNov 22, 2017NETGEAR Moderator
- jsirgeyDec 03, 2017Aspirant
i'm having this issue on one of my pc's but not the other Router is R6400, can anyone help?
