chuckdblake's avatar
chuckdblake
Follower
Mar 07, 2020
remote management
I am trying to get my NightHawk APP to connect to my router but I did not connect the APP before I left my home, I do have Remote Management turned on in the router but I still can't connect to it with the APP, I have access to my router through remote desktop, Is there a way to still get the APP connected.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    chuckdblake wrote:
    ....but I still can't connect to it with the APP
    What hap;p;ens when you try?
    Do you know the router's WAN IP address?
    If you visit the support pages:
    Support | NETGEAR
    you can feed in the model number and find the documentation, and, if there are any, firmware versions and drivers for your hardware.
    Read the section Use Remote Access.
