Jacob-clackett
Oct 20, 2021Aspirant
Router nicknames
Please see my screen shot. Does anyone know how to name these routers so on the Android Nighthawk app I can distinguish them from each other? If I click on one and then click on the image of the router I can see some information including the name I assigned it, but I wish I could see at a glance which one is offline without having to do an elimination process.
Um, unlessy your managing several same model routers which I presume you only have 1 model router, only 1 router should be seen in this list....
What device do you have NH App installed on?
What version is the NH App?
- Jacob-clackettAspirantAndroid version 2.12.0.1770.
I have these routers in my vacation homes and the houses are connected by point to point antennas. I live in a remote area with limited internet coverage, so I have to make my own network between houses.- FURRYe38Guru - Experienced User
Does the 3 vertical dots have any options?
