JohnDebi's avatar
JohnDebi
Signing up for DNS
Trying to sign up for the OPENDNS account for parental controls. Keeps telling me 'action failed' after successfully creating username and password. Help!
  • Hi JohnDebi,
    1. Please try using another device (iOS, Android, another computer).
    2. What is the firmware version of the router?
    3. Have you tried re-installing the app?
    4. Are you able to login via a web browser (https://netgear.opendns.com/sign_in.php) using the credentials?
    Dexter
    Community Team
  • To be clear, Not a Netgear armor question, but I had to put a label in. I am trying to use the Netgear Genie app to sign up for the OpenDNS.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi JohnDebi,
      Dexter
      Community Team
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi JohnDebi,
        I would like to follow up and check if you are still experiencing the issue.
        Dexter
        Community Team
