mikepinkston's avatar
mikepinkston
Follower
Dec 03, 2024
start over in the Nighthawk app
I tried to use the Nighthawk app for two seperate networks, my mom's and mine.  This is a disaster.  How do I delete everything in the app and start over?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    What was the problem? This should work just fine. I do it all the time.
    Hard to tell how to dig you out of the hole not knowing what the problem is.
    If you can see both devices/networks, you just delete the one you don't want.
    Failing that uninstall the app is a regular trick.
    Just another user with time on their hands.
