Bosco78
Mar 18, 2025Aspirant
System down for maintenance
Why is Netgear still down for maintenance. It is 9:15am here in the eastern time zone. The maintenance was supposed to end at 2:30 am. PT. It is Tue. March 18.
Hi R_hernan,
Check the router if Access control is enabled. If yes, try disabling it.https://kb.netgear.com/24830/Configuring-Access-Control-on-Nighthawk-Wi-Fi-Router
Something to and NG support about.
Or submit a bug report:https://community.netgear.com/t5/Nighthawk-App/How-to-report-a-bug-on-the-Nighthawk-App/td-p/2134684
I can't submit a bug, because it closes the app, when I hit the dismiss notification.
"We are currently down for a scheduled maintenance. Our systems will down March 24th for 12:30a - 2:30a PT."
The grammar and date is not correct either. Is this a hack?
Does the bug feature appear if you shake the phone on the notification screen?
I submitted the bug that way. Great work around. And it captured the screen to submit. Thanks.
Now hopefully, with the number of people viewing, more can submit the bug.
