Stackb
Nov 08, 2017Follower
Time limit controls by device
I just purchased the X6 and have a simple question (hopefully)
Can I set up user/device time settings by device. I know I can set the router up to limit access in broad terms, but I need to be able to shut my kids individual devices down during certain blocks of time. Is that possible? If so can you pleae point me in the right direction. FYI I have already looked at the manual for the AC3200 but it isn't clear to m e.
Many thanks
Hi Stackb,
You may want to look into the Circle feature of your router (R8000). Make sure your router is using the latest firmware (1.0.4.4). The links below may help in giving you an overview of the feature.
https://kb.netgear.com/000038873/
http://www.netgear.com/landings/circle/
https://kb.netgear.com/000038872/
Dexter
Community Team
1 Reply
- DexterJBNETGEAR Moderator
Hi Stackb,
Dexter
Community Team
