Kepyslap
Dec 29, 2017Aspirant
Turn WiFi off for selected users?
Wanted to know if there is a way I can turn WiFi off for certain devices (my son’s iPhone) but still have remainder of house connected to WiFi!
Kepyslap
This is great information and I thank you! The only problem is that I am having trouble finding the location that you have directed me to. I am using the genie app and can't find the advanced/security/access control location. Any suggestions?
Thank you
TheEther
Dec 29, 2017Guru
I've never used the Genie app, so I can't help you with that.
Just log into the router with a web browser. The default address is 192.168.1.1.
Or you can try visiting http://routerlogin.com. This should actually go to your own router. You must be connected to the router's Wi-Fi or one of its LAN ports for this to work.
