ganatbasa
Apr 13, 2023Follower
Turning off access anywhere
I have the rax10 ax1800 and need to turn off access anywhere, I don’t want it on. The nighthawk app won’t let me do it, says it needs to be done locally. But when I log into the router locally ther...
michaelkenward
Apr 14, 2023Guru - Experienced User
ganatbasa wrote:
The nighthawk app won’t let me do it, says it needs to be done locally. But when I log into the router locally there’s no option for it….
Which app? iOS? Android?
By "locally" it meas that you use Anywhere Access and then use the "Connected Locally" option.
Then, go to
- Settings
- Anywhere Access
- Enable/Disable Anywhere Access
