Rajats's avatar
Rajats
unable to setup
I am not able to connect to router and its saying firmware issue
  • michaelkenward's avatar
    michaelkenward
    What Netgear device is this?
    What is it connected to on your network? What modem/gateway, if there is one, sits in front of it?
    Which app are you using? Android? iOS?
    Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
  • I am using netgear r7000 AC1900. Can I have any call support?
      michaelkenward
      Yes if it is a new router within 90 days of purchase.
      The official support channels start here:
      Contact Us | Support | NETGEAR
      First you have to register your device to confirm that it is eligible for the 90-days free support. Start here:
      MyNETGEAR | Product Registration
      Start a case and, with luck, they will contact you.
      After 90 days, Netgear does not provide paid support. It farms that out to GearHead.
      GearHead Support
      GearHead supports all manner of kit, but it isn't likely to try flogging things like firewalls and virus checkers.
      Or you can try to sort out problems here. That costs you nothing.
