sscaltri
Mar 03, 2026Initiate
WiFi strength on Nighthawk App
I no longer see the wifi strength. I see the connected devices but not the strength. The wifi bands would be darkened. Now they are all light gray. Happens on both phone and iPad.
Mar 03, 2026Guru - Experienced User
What model NG router do you have?
- sscaltriMar 03, 2026Initiate
RS700S
- FURRYe38Mar 03, 2026Guru - Experienced User
What model iphone and pad do you have?
Is Smart Connect enabled on the RS router?
Might submit a bug report thru the app for this item:
How do I submit a bug report or logs from the Nighthawk or Orbi app? | NETGEAR Communities
