jelsomino's avatar
May 29, 2016
WNDR4700 - Unable to connect to some sites
Hopefully someone can help mp resolve this issue
I have WNDR4700 with V1.0.0.52Comcast Internet and I noticed that some sites failed to load, so I tracert them and it failed on my router
tracert www.serviio.org
Tracing route to serviio.org [5.102.184.26]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms READYSHARE [192.168.1.1]
2 READYSHARE [192.168.1.1] reports: Destination host unreachable.
What is weird that if use my company VPN I have no problem with connection to the same web pages. I blamed router's DNS setting so I changed them to Comcast recommended and then to Google's. Didn't resolve the problem
I almost certain it's not Comcast but something in my settings because when I connect to Xfinity open WiFi that's running in my neighborhood I have no problem with connection
  • Destination host unreachable indicates a routing problem.  This error seems to be coming from your router, which is a bit unusual because the router should be sending all Internet traffic upstream to your ISP.
    Do you have any static routes configured on the router?
    Are you blocking any services on the router?
    If you go the Advanced settings and click on Connection Status, do you see the default gateway set?
    • jelsomino's avatar
      jelsomino
      Tutor
      Thank you replying,
      No
      No
      My IP address in Connection Status shown as XX.XXX.XXX.136, my Default Gateway is XX.XXX.XXX.1 all previous digits are the same
      • TheEther's avatar
        TheEther
        Guru
        Hmm.  Try a factory reset.  Do you have the latest firmware installed?
