Frank1228
Apr 06, 2020Aspirant
wouldn't be able to login to nighthawk app model r7960p
hi there,
i found i woudn't be able to to log on the nighthawk app, i tried delete the app and resinstall, and i have updated the firmware to V1.4.1.50_1.3.10 which i believe the newest version, but the app kept giving me error message:"logon timed out, please try again.if this issue persists, try rebooting your device."i did reboot. doesn't work.
- Frank1228Aspirant
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router.- Frank1228Aspirant
sorry, i'm using a CM1100 modem and nighthawk x6-ac3000 router. somehow the app works later last night, i don't know what happened, but i just login now. i do have another quesiton, my upload speed is extreamly low compare to the upload speed, like is 15 mbps vs 700 mbps, called comcast, its not their end issue. can you help?
