duglee64
Sep 30, 2025Aspirant
Wrong network password
I was trying to reconnect via wifi to my HP printer. It asked me for the network password. I typed it in and it said it was the wrong password, but it wasn't. I tried to connect to another printer th...
CrimpOn
Sep 30, 2025Guru - Experienced User
duglee64 wrote:The printers were already connected at one time. They lost the connection and I was trying to reconnect them.
Thanks for the answers. Assuming these printers are connected to the Nighthawk with WiFi, many printers can use a WPS button to connect to WiFi. What are the model numbers of the HP and Canon printers? (so I can look up the User Manual to see if they support WPS)
- duglee64Sep 30, 2025Aspirant
Canon - TS3300
HP - Laser Jet MFP M140
- StephenBSep 30, 2025Guru - Experienced User
Did you try installing the HP Smart app on your phone? Instructions for connecting it to your wifi network are page 7 of the manual
duglee64 wrote:
Canon - TS3300
You can set up the network name and password from the LCD screen here.
When done, you can double-check that both printers show up in the attached devices list of the C7000. Consider reserving an IP address for both printers in the router.
duglee64 wrote:
I was trying to reconnect via wifi to my HP printer. ...
If you still have having trouble connecting to the printers from the PC, then you might try simply removing them from the PC and re-adding them. I've sometimes had to do this with my own printers.
