duglee64
Sep 30, 2025Aspirant
Wrong network password
I was trying to reconnect via wifi to my HP printer. It asked me for the network password. I typed it in and it said it was the wrong password, but it wasn't. I tried to connect to another printer th...
CrimpOn
Sep 30, 2025Guru - Experienced User
Thanks for the model numbers. The HP M140 appears to support WPS connection to WiFi:
CrimpOn wrote:The HP M140 appears to support WPS connection to WiFi
Yes it does. But we don't actually know that these printers need to be reconnected to the wifi. All we know is that the computer isn't reaching them for some reason. I've sometimes seen that happen with my one of my own computers, and for me what was needed was to reinstall the printer(s) on the PC.
duglee64 - have you reviewed the device list on the router, and confirmed that neither printer is connected to the network?
- duglee64Oct 01, 2025Aspirant
Here's what I know so far. The printer is on the device list of all of my computers. I have uninstalIed and reinstalled HP Smart app. I noticed that when I try to connect to the router and it asks for my routers password, the wi-fi disconnects every time. It only does this for my printer.
- FURRYe38Oct 01, 2025Guru - Experienced User
You'll need to check with HP and what this password is for your printer. Most HP printers now days have a log in password and admin/user level accounts and passwords on there printers. Something to ask HP support about.
- StephenBOct 01, 2025Guru - Experienced User
But is it still in the device list of the router????
One possibility is that the HP smart app is trying to set up the printer using WiFi Direct.
Yes, The HP printer is listed on the device list.
I don't know if you have seen my other replys, but I noticed that when I try to connect to the printer via wi-fi, it asks for the router password and as soon as I try to enter the secuity key, I lose wi-fi.
