A-nonymous
Nov 14, 2022Aspirant
XR500, Night Hawk app not allowing me to check my routers speeds
Hello, I haven't used the night hawk app in a while. I just opened it to see the exact amount of speed my router is getting from my network provider and I noticed that the app doesn't allow me to do ...
Nov 14, 2022Guru - Experienced User
Try changing to the Local Network connection with in the app. Select the 3 horizontal bars then change the Connect via Anywhere Access to Local
- A-nonymousNov 14, 2022Aspirant
I've tried both Local Network connection and remote. Both are showing me the same options...
- FURRYe38Nov 14, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Try this app on a different mobile device if you can?
How is QOS configured on the router?
It's appearing on my XR1000 and it's using Anywhere Access here at work.
I haven't had my XR450 online in a while...I'll check this when I get home.
Only thing I can think of is that the app is not working correctly...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
- FURRYe38Nov 15, 2022Guru - Experienced User
OK I was able to reprduce this today on my XR450 (router mode v.134) as well. Speed test is not present on the NH app.
Have you loaded the Duma OS app yet?
Lets get this to NG and see whats happening.
