A-nonymous
Nov 14, 2022Aspirant
XR500, Night Hawk app not allowing me to check my routers speeds
Hello, I haven't used the night hawk app in a while. I just opened it to see the exact amount of speed my router is getting from my network provider and I noticed that the app doesn't allow me to do ...
A-nonymous
I've tried both Local Network connection and remote. Both are showing me the same options...
Nov 14, 2022Guru - Experienced User
Try this app on a different mobile device if you can?
How is QOS configured on the router?
It's appearing on my XR1000 and it's using Anywhere Access here at work.
I haven't had my XR450 online in a while...I'll check this when I get home.
Only thing I can think of is that the app is not working correctly...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
