TomFoord's avatar
TomFoord
Initiate
Apr 24, 2024
Meural web interface shut down?
I can no longer access the web interface to my meural canvas. Has it been discontinued or perhaps moved? When I use the url that used to work, I get error messages.
  • plemans's avatar
    Just pulled mine up and it works fine.
    Is your connected to the wifi (check on the meural)?
    • TomFoord's avatar
      TomFoord
      Initiate
      My URL was in error. Using the correct URL, everything's fine. Thanks for reaching out.
      • plemans's avatar
        Glad you got it working!
        Might mark it solved so others aren't still trying to fix the issue 🙂
