Rich_R's avatar
Rich_R
Black Screen randomly displays
Canvas software version 2.0.9
Good afternoon. I have seen this issue posted before from others, though I didn’t see a solution.
When playing my Playlist, every fifth or so image is a black screen with a small great area in the upper left hand corner. I have checked the Playlist in the app on my phone and don’t see any images blacked out. Can anyone please advise how I can correct this? Thank you
  • Hi Rich - if it’s 4 years old then you’re well out of any Netgear or extended warranty, and consumer rights won’t be helpful here - 4 years is a good life and any longer is a plus. I’d enquire about repair costs but I’d be first tempted to try a factory reset and setup again from scratch. If the repair is too costly then I’d have a fiddle inside for any loose connectors as at that point you’ve got nothing to lose 🙂 Good luck!
  • Looking at similar posts, this issue has been fixed by powering off the canvas for at least 30 seconds. Other posts suggested an RMA was the solution to their particular issue. Try the powering off and see if that resolves it.
    • Rich_R's avatar
      Rich_R
      Thanks Jeff, for responding on Christmas!
      I have tried powering off the Meural, but unfortunately it didn’t fix it. By “RMA” are you saying returning the unit? It’s been about 4 years so I assume I’m out of warranty. I could ask what the company would charge for a repair.
      Thanks again,
      Rich
      • Jeffgear's avatar
        Jeffgear
        Virtuoso
