lechner
Aug 22, 2025Aspirant
Can't get Meural online
I successfully reset my Meural Canvas 2nd generation but it restarts saying: To get set up Follow these steps First get Meural App (done) Open Meural App and login (done) ======= B...
lechner
Aug 24, 2025Aspirant
No progress yet. The router has changed but the network name and password are the same. When I restart the Meural it doesn't respond to waves at either sensor. So I can't get to a menu to restart the WiFi. I've tried connecting directly to the network on the Meural and that name shouldn't have changed. But however I try it requires that the Meural respond so I can get to the WiFi menu. I'm thinking I should remove it from the Meural App and try and start from scratch. But it seems like the panel has to allow me to get to the menus for any chance of getting it set up.
