","body@stringLength":"940","rawBody":"
I have been experimenting.
If the photos are JPEG then it works. If Apple HEIF and after a variant of iOS 15 (not sure which but mid last year), then the linked album is empty and cannot be synced. It goes through the download process and progress bar in Meural app but the linked album never refreshes and remains empty.
All my own photos in iCloud that are HEIF upload fine to Meural, manually to new playlists or via linked albums.
if I create a shared album in iCloud, add photos that are JPEG and HEIF, then create a linked album in Meural to this iCloud shared album, only the JPEG's sync up to Meural. Yet I can manually add those HEIF photos to a playlist.
The Meural linked album process rejects HEIF images from iCloud shared albums but these same photos can be manually uploaded into Meural library playlists.
","author":{"__ref":"User:user:963843"},"isEscalated":null,"postTime":"2022-10-26T00:11:49.781-07:00","solution":false,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[],"messagePolicies":{"__typename":"MessagePolicies","canReply":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","key":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","args":[]}},"canAcceptSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","args":[]}},"canRejectSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","args":[]}},"canTag":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","key":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","args":[]}},"canEdit":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","key":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","args":[]}},"canKudo":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","key":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","args":[]}}}},"Revision:revision:2270886_2":{"__typename":"Revision","id":"revision:2270886_2","lastEditTime":"2022-11-09T23:39:34.173-08:00"},"QueryVariables:ReplyList:message:2270886:2":{"__typename":"QueryVariables","id":"ReplyList:message:2270886:2","value":{"id":"message:2270886","sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":false,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-components/customComponent/CustomComponent-1759227961148":{"__typename":"CachedAsset","id":"text:en_US-components/customComponent/CustomComponent-1759227961148","value":{"errorMessage":"Error rendering component id: {customComponentId}","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1759227961148":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1759227961148","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1759227961148":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1759227961148","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/common/ExternalLinkWarningModal-1759227961148":{"__typename":"CachedAsset","id":"text:en_US-components/common/ExternalLinkWarningModal-1759227961148","value":{"title":"Leaving the Community","description":"You're about to leave this site and navigate to an external domain. Are you sure you want to continue?","action.submit":"Continue","action.cancel":"Go Back"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1759227961148":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1759227961148","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-components/messages/LinearReplyList-1759227961148":{"__typename":"CachedAsset","id":"text:en_US-components/messages/LinearReplyList-1759227961148","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"Rank:rank:41":{"__typename":"Rank","id":"rank:41","position":31,"name":"Initiate","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:1064450":{"__typename":"User","id":"user:1064450","uid":1064450,"login":"johndmeara","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-01-13T12:11:14.719-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":null},"rank":{"__ref":"Rank:rank:41"},"entityType":"USER","eventPath":"community:ejquo23388/user:1064450"},"ModerationData:moderation_data:2291097":{"__typename":"ModerationData","id":"moderation_data:2291097","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2291097":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:1064450"},"id":"message:2291097","entityType":"FORUM_REPLY","eventPath":"category:en-home-networking-meural/category:home-networking/category:English/community:ejquo23388board:en-home-networking-meural-canvas/message:2235796/message:2291097","revisionNum":1,"uid":2291097,"depth":18,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:en-home-networking-meural-canvas"},"parent":{"__ref":"ForumReplyMessage:message:2270886"},"conversation":{"__ref":"Conversation:conversation:2235796"},"subject":"Re: Can't upload iCloud images form linekd album","moderationData":{"__ref":"ModerationData:moderation_data:2291097"},"body":"
Thanks for this info. I think it holds true for all, but I'm just disappointed with Netgear/ the Meural. I absolutely love it but I am constantly dealing with syncing issues. I too learned about the HEIFs and issues with linked albums. Support just tells me to add them via a playlist and I try to tell them that it completely defeats the point of a linked album that I can update through my phone. Generally disappointed and sick of the amount of time invested in trying to figure out how to get my three meurals to act like I want them to.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"218","kudosSumWeight":0,"postTime":"2023-01-30T08:18:55.423-08:00","lastPublishTime":"2023-01-30T08:18:55.423-08:00","metrics":{"__typename":"MessageMetrics","views":5587},"visibilityScope":"PUBLIC","placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"repliesCount":2,"readOnly":false,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"messagePolicies":{"__typename":"MessagePolicies","canReply":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","key":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","args":[]}},"canAcceptSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","args":[]}},"canRejectSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","args":[]}},"canTag":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","key":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","args":[]}},"canEdit":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","key":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","args":[]}},"canKudo":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","key":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","args":[]}}}},"ModerationData:moderation_data:2319738":{"__typename":"ModerationData","id":"moderation_data:2319738","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2319738":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:1064450"},"id":"message:2319738","entityType":"FORUM_REPLY","eventPath":"category:en-home-networking-meural/category:home-networking/category:English/community:ejquo23388board:en-home-networking-meural-canvas/message:2235796/message:2319738","revisionNum":1,"uid":2319738,"depth":19,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:en-home-networking-meural-canvas"},"parent":{"__ref":"ForumReplyMessage:message:2291097"},"conversation":{"__ref":"Conversation:conversation:2235796"},"subject":"Re: Can't upload iCloud images form linekd album","moderationData":{"__ref":"ModerationData:moderation_data:2319738"},"body":"Couldn't agree more with this sentiment. Bought high end items that I love but are not used to their full potential due to syncing issues. I'm sick of investing time and dealing with unhelpful NG Support (polite but don't resolve the issue). I also don't understand how or why this issue cannot be remedied by NG.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":1,"postTime":"2023-06-26T07:46:19.784-07:00","lastPublishTime":"2023-06-26T07:46:19.784-07:00","metrics":{"__typename":"MessageMetrics","views":4745},"visibilityScope":"PUBLIC","placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"repliesCount":1,"readOnly":false,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"messagePolicies":{"__typename":"MessagePolicies","canReply":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","key":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","args":[]}},"canAcceptSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","args":[]}},"canRejectSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","args":[]}},"canTag":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","key":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","args":[]}},"canEdit":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","key":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","args":[]}},"canKudo":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","key":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","args":[]}}}},"ModerationData:moderation_data:2319812":{"__typename":"ModerationData","id":"moderation_data:2319812","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2319812":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:963843"},"id":"message:2319812","entityType":"FORUM_REPLY","eventPath":"category:en-home-networking-meural/category:home-networking/category:English/community:ejquo23388board:en-home-networking-meural-canvas/message:2235796/message:2319812","revisionNum":1,"uid":2319812,"depth":20,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:en-home-networking-meural-canvas"},"parent":{"__ref":"ForumReplyMessage:message:2319738"},"conversation":{"__ref":"Conversation:conversation:2235796"},"subject":"Re: Can't upload iCloud images form linekd album","moderationData":{"__ref":"ModerationData:moderation_data:2319812"},"body":"I regularly check the app to see if any of my iCloud shared and linked albums populate with the photos the sharers are adding, but none upload. I did some further testing and only jpeg sync but none of the default heic format Apple uses. However pre ios 15.x heic do sync ok. I don’t know the exact version or date Thai stopped but it was over a year ago.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":1,"postTime":"2023-06-26T11:55:46.919-07:00","lastPublishTime":"2023-06-26T11:55:46.919-07:00","metrics":{"__typename":"MessageMetrics","views":4732},"visibilityScope":"PUBLIC","placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"repliesCount":0,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"messagePolicies":{"__typename":"MessagePolicies","canReply":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","key":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","args":[]}},"canAcceptSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","args":[]}},"canRejectSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","args":[]}},"canTag":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","key":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","args":[]}},"canEdit":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","key":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","args":[]}},"canKudo":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","key":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","args":[]}}}}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"en-home-networking-meural-canvas","messageSubject":"cant-upload-icloud-images-form-linekd-album","messageId":"2235796","replyId":"2270886"},"buildId":"iWB5jxAgv6Dzg8_YScW7W","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","appLogLevelOverrides":"TenancyMiddleware=TRACE,OriginHelper=TRACE","logLevelMetrics":"info","surveysEnabled":true,"openTelemetry":{"clientEnabled":false,"configName":"netgear","serviceVersion":"25.9.0","universe":"prod","collector":"http://localhost:4318","logLevel":"error","routeChangeAllowedTime":"5000","headers":"","enableDiagnostic":"false","maxAttributeValueLength":"4095"},"apolloDevToolsEnabled":false,"quiltLazyLoadThreshold":"3"},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["components_seo_QAPageSchema","components_community_Navbar_NavbarWidget","components_community_Breadcrumb_BreadcrumbWidget","components_customComponent_CustomComponent","components_messages_TopicWithThreadedReplyListWidget","components_languages_LanguagePicker","components_messages_MessageView_MessageViewStandard","components_external_components_ExternalComponent","components_messages_EscalatedMessageBanner","components_customComponent_CustomComponentContent_HtmlContent","components_customComponent_CustomComponentContent_CustomComponentScripts","shared_client_components_common_List_UnstyledList","components_messages_MessageView"],"appGip":true,"scriptLoader":[]}
