Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
Oct 08, 2024Guru - Experienced User
NG is aware of this and is working on a fix. Not time frame on final fix. So please be patient.
If you feel you need more help and information, please make contact with NG support.
Thank you.
KevinLiT
Oct 18, 2024NETGEAR Moderator
Best,
Kevin
Community Team
