BarnacleBill's avatar
BarnacleBill
Follower
Mar 26, 2022
Meural Alexa skill has disappeared
I looked on the Alexa skills store this morning to see whether there have been any recent updates to the Meural skill.  I keep hoping (somewhat naively it seems) that Netgear will update the skill so that I could ask Alexa 'what's my Meural Canvas showing?' and that Alexa would read out the name of the painting and the artist.  (Ideally this would work with two canvases by using each Canvas' name).
So I checked with Alexa itself and although Alexa can still see my Meurals and says the devices are connected 'via Meural' I can't even use even the basic controls that used to exist anymore.  When I check, it seems the Meural skill is no longer in the Alexa store!
Has anyone else noticed this?
    • slf's avatar
      slf
      Just received a reply from Alexa support stating "The skill has disappeared and should be reinstated soon.  It is a 3rd party skill issue and the skill owner is working on it, no worry.  Please check back in a couple of hours."
      • slf's avatar
        slf
        Amazon support says the netgear meural skill is no longer on their site. Netgear needs to reestablish the skill on Amazon.
        We've been on the phone with Netgear support folks for hours trying to get to someone that knows something about the Meural products.....not very reassuring.
  • ChristineT's avatar
    ChristineT
    NETGEAR Employee Retired
    Hello BarnacleBill and slf ,
    Thank you for sharing your issue here on the NETGEAR Forum. We are looking into this issue and will provide an update just as soon as possible.
    Best,
    Christine
    • KevinLiT's avatar
      KevinLiT
      NETGEAR Moderator
      Hello SkiingNana,
      Welcome to the NETGEAR Community!
      Just to clarify, when does Alexa give you the message "she can't find NULL"?
      Best,
      Kevin
      Community Team
      • SkiingNana's avatar
        SkiingNana
        I renamed meural to canvas, and I only ask her to "turn on the canvas" or turn off the canvas." It used to work, but now either request gets the message, "Hmm, I'm having trouble reaching null." This has been failing like this over a month.
