Saif87's avatar
Saif87
Follower
Mar 22, 2024
Meural canvas has a browser open ion display
My meural is showing a browser page with address set to 127.0.0.1/frame. Its still connecting to the app and loading pics in this browser. Is it some sort of debug mode. How can i get rid of it? Any help is greatly appreciated.
  • Problem solved by performing a factory reset of the canvas:
    1. You need a paperclip (or pen or other slim object) to press the reset button with
    2. Disconnect the power cord from your Canvas
    3. Locate the small/recessed reset button near the micro USB port and micro SD card port on your Canvas
    4. Using the paperclip, firmly press and hold the reset button
    5. While continuing to hold the reset button, plug the power cord back into your Canvas
    6. Wait 20 sec, then release the reset button
    7. The Canvas automatically reboots.
  • I am having the same problem. Has this been resolved? I've tried power off/on, removing it from my iOS app, clearing its WiFi... nothing works.
