joey301
Oct 14, 2024Star
Meural is offline
I could not figure out how to post this as a response to the stream that is already started on this subject, I could not find ANY reply options, so I came here. I sent this to Netgear this morning af...
Oct 14, 2024Guru - Experienced User
Not much else can be done. All in NGs hands currently. You'll need to keep in contact with NG support and be patient while NG gets this figured out.
Thank you.
KevinLiT
Oct 18, 2024NETGEAR Moderator
Hello joey301 ,
Welcome to the NETGEAR Community!
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.
We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
