Mojomania
Aug 31, 2020Aspirant
Meural Resizing My photos
I understand that the resolution of the Meural Canvas is 1920x1080 pixels. I don't want Meural to auto-size the photos to fit the frame because it distorts the photo. I used Photoshop to edit all of my photos to for either the 1920 width of the 1080 height (allowing for some black filler on the short side.)
I have one Playlist that works perfectly. However, I just uploaded a new Playlist yesterday and the Canvas is auto-sizing and distorting the photo. Are there any solutions for this?
Hello Mojomania,
You should be able to change this setting by following the steps below
- log into the Meural App
- Click on Canvas
- Click the Settings icon in the upper right hand corner of the screen
- Scroll down to find "Display" settings
- Change Fill Mode to Contain or As is
Try this out and let us know if you're now able to view your images in the desired format.
Kind Regards,
Christine
- ChristineTNETGEAR Employee Retired
Hello Mojomania,
- Click on Canvas
Kind Regards,
Christine
