Jacobcamacho's avatar
Dec 22, 2024
Meural WIFI photo frame apps dont work. Invalid credentials message.
Connection to app stopped working. Receive message Invalid credentials on Android phone and tablet. Same issue with IOS. Stuck with actual pics and configuration. Resetting password does not solve it. It's a glitch, not a password issue. Cannot do anything with this nice looking brick.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello Jacobcamacho,
    Welcome to the NETGEAR Community!
    I understand that you are not able to log onto your Meural app using the Android operating systems due to unrecognized credentials.
    Are you able to log into my.meural.com using the same credentials you initially used on your Meural app?
    Best,
    Kevin
    Community Team
    • Jacobcamacho's avatar
      Jacobcamacho
      Tutor
      That is correct Kevin. I log in to my meural online. But the app gives invalid credentials error. I tried to change the password, but that did not help. Online account works, but app doesn't.
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello Jacobcamacho ,
        Thank you for verifying that information!
        Please follow the steps below to resolve the issue:
        First, uninstall then re-install your Meural app to ensure that your Meural app in up-to-date.
        Next, Navigate to my.meural.com.
        Next, Select your initials on the far right.
        Next, Select Canvases.
        Next, Scroll down to Canvas Software Version.
        Next, Select the arrow on the right of the software version.
        Next, Select update on the top right.
        Then, connect to the same wireless network as your Meural Canvas.
        Now, log into your Meural app.
        Then, select "CANVAS".
        Please keep me updated on the progress of this issue!
        Best,
        Kevin
        Community Team
