Thunder2100
May 12, 2025Aspirant
Netgear Meural, blank screen after logo...
Hi, I've got a couple of Netgear Meurals and they're lovely. But, one of them is now just showing a Meural logo and then, after that, it just goes blank. I've done a hard reset on the unit ...
Thunder2100
Hi Mark,
After the reset, the Meural logo goes and the unit goes blank. Nothing shows on the screen at all.
It's almost as if the unit doesn't have enough power to boot up properly and shuts down.
As there's no power light indicating it's switched on, I can't tell if that's what's happening.
Should I try a more powerful power supply?
- IponderitJun 27, 2025Aspirant
I have the same problem and have not found an answer. Now it is worthless.
