Mr_Oizo
Nov 27, 2020Aspirant
Slideshow with Meural WiFi Photo Frame
Hello dear Community,
I did not found an answer to my question on the available FAQ.
Is it possible to create, on this photo frame, a slideshow of selected photos by defining a display duration?
Many thanks for your answer.
Best regards,
Mr Oizo
You can set the amount of time each picture displays for. Its usually how I do it.
Is that what you mean?
- Mr_OizoAspirantThank you for the answer.
In fact my need is much more basic. It is about automatically scrolling through the photos with an interval of a few seconds, instead of having a photo frozen in the frame.- plemansGuru - Experienced User
You can set the image duration from 1 second on up. I just changed it on mine and it worked fine
