Auddi
Aug 09, 2023Follower
Adding a add on mesh ms60 to my system
I have tried everything, I just purchased a ms60 add on to add to my system. It flashes white for a few minutes then turns red. On the app it says it can’t find it when it flashes white. I have tri...
michaelkenward
Aug 10, 2023Guru - Experienced User
Did you find this?
Solved: Re: MK6x: MR60/MS60 attempting to add six MS60 's ... - NETGEAR Communities
Top hit when I tried this:
Search - NETGEAR Communities – add on mesh ms60
I did that because I recall seeing similar issues in the past.
For a start, did you ensure that all devices are on the same firmware?
Have you tried using the browser graphical user interface (GUI) to add the satellite?
