cpthk
Dec 14, 2023Aspirant
Anyway to tell which band and channel the satellite backhaul is using?
My devices that connect to the satellites are having slow internet. Speed test showing only ~ 5mbps. I am suspecting the problem is the backhaul connection from satellites to the main router. Is there a way to tell which band and channel they are using? I could not find that in the web ui.
MS use and channels as MR. Shown on WEB UI under advanced tab.
