c_of_c's avatar
c_of_c
Star
Jan 19, 2024
Best Nighthawk Mesh System to upgrade to from R7960p?
Hello,
I currently have Netgear Nighthawk R7960p router (Nighthawk X6S) model.I am looking to upgrade to a mesh system, as my home has 3 levels and a mesh system will provide better coverage. Which Nighthawk Mesh system would be best to upgrade to, from a features perspective? I can read the various specs, but was wondering if anyone has a "real life" experience of moving from a R7960p router to a mesh system.
  • FURRYe38's avatar
    What future proof devices do you have or may look to have in the future? Such as supporting of 6ghz?
    I still have my R7960p router however hasn't been used in a long time. Even when I had it online, I needed one extender to help wifi signals in a 5000 sq ft home with 2 levels and a basement. Moved on to testing Orbi and MK systems. Though I have both wireless and wired infrastructure, I prefer using ethernet for any remote satellite placements. MK systems are good however the one in the basement always seems to have poor connection vs a Orbi satellite which seems to be a bit more powerful when wirelessly connected. Ethernet connections for any satellite will always be more stable and out perform wireless connections.
    • c_of_c's avatar
      c_of_c
      Star
      Home is 3200 sq ft on 3 levels. Have about 50 WiFi devices supporting smartphones,laptops, tablets, security cameras, thermostat, streaming devices All 2.4 or 5ghz. R7960p is on lowest level (that is where cable enters the house) and signal reaches all areas but not as powerful on top level or outside. Also have wired devices but mainly on the first level, a couple on the second level via powerline. Future devices, it just depends, I hack around but rarely do anything "leading edge".
