IainMurray
Apr 05, 2021Tutor
Cannot Login Using Browser
I have a problem with a New Nighthawk MR60 system where I cannot Login suing the we browser Interface After 3 attempts it asks my Serial Number and Security questions and allows me to rest the Password. This put me in a loop where I cannot Login Again. I have had this system about 2 months and have never been able to login, even a Factory Reset does not help.
Curious, you used the default username and password for the login?
Default Setting
Router login User login URL http://www.routerlogin.net
User name (case-sensitive): admin
Login password (case-sensitive): password
- Christian_RNETGEAR Employee Retired
Hello lainMurray,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Default Setting
Login password (case-sensitive): password- This indeed might be my problem... duh I now have access .... I was using “Admin” not “admin” I normally use capital letters to start passwords etc
- mingjkliAspirant
sorry, i made a mistake to reply
