vish_at
Feb 03, 2026Aspirant
cant change IP address range values in LAN DHCP setting
I am using MR60 router. I cant change DHCP range in LAN setting from admin console. As soon as I change ending IP address (last four digits) from 10.0.0.254 to 10.0.0.250 and click Apply, the router ...
CrimpOn
Feb 08, 2026Guru - Experienced User
What was the purpose of erasing the LAN setup display to show only the last parts? (2 and 254) Since the erased part is supposed to be 10.0.0, there is nothing "sensitive" about this information.
coolwifi
Feb 08, 2026Virtuoso
Looks like it has been changed and disabled to avoid double NAT with the ISP gateway.
- StephenBFeb 09, 2026Guru - Experienced User
The internet setup screen clearly shows the router is connected to a gateway, since the WAN is a 192.168.1.x address.
But double NAT is not as evil as many posters here suggest, and isn't related to the problem vish_at is asking about. The only ways to avoid double-NAT are to set up the ISP gateway in bridge mode, or set up the MR60 as an AP. Disabling the LAN DHCP server range settings won't do it.
coolwifi wrote:
What's the need to change to the ending LAN ip address from 254 to 250?
That would be good to know. Often the goal is to allow some static IP addresses. But whatever the reason, it should work.
vish_at - have you tried changing the starting IP address from 2 to 6? Does that also fail to stick?
Have you tried doing a factory reset of the router?
- vish_atFeb 09, 2026Aspirant
Want to reserve static IP for PI-hole as per this screen. https://snipboard.io/qVEaYs.jpg
Again, as soon as I click Apply, the router reboots and reservation goes away and router goes back to default set up. No changes work, everything goes back to default.
- FURRYe38Feb 09, 2026Guru - Experienced User
Can you make changes with out the router connected to the ISP modem/router and PiHole at all?
Does setting up a IP address reservation for just one connected PC work at all?
What happens if you change the MR IP address to begin at 10.0.0.50 and end at 10.0.0.200?
Then set a static IP address ON the PiHole to .37 here?
What happens if you change the MR IP address to 192.168.0.1 and then set the DCHP range to 192.168.0.100 to .200?
I've used this on my MR60...
You seem to have a router at the ISP level since your IP address seen on the MR seems to be a 10.0.0.x address as this indicates the MR changed from 192.168.1.1 from default to avoid what was seen at the ISP modem level that it maybe using here.
What browser are you using on the MRs web page to make changes?
Try making changes with the MR disconnected from the ISP modem/router.
- coolwifiFeb 09, 2026Virtuoso
Yes, double NAT isn't preventing the DHCP pool range assignment for the OP.
