vish_at
Feb 03, 2026Aspirant
cant change IP address range values in LAN DHCP setting
I am using MR60 router. I cant change DHCP range in LAN setting from admin console. As soon as I change ending IP address (last four digits) from 10.0.0.254 to 10.0.0.250 and click Apply, the router ...
CrimpOn
Feb 09, 2026Guru - Experienced User
Do the DHCP pool starting and ending addresses actually appear on the screen with the first three octects very faint (very hard to read), or did you change the screenshot before posting it?
The discussion started about changing the DHCP pool values. Now it appears that attempting to set a reservation also fails?
