vish_at
Feb 03, 2026Aspirant
cant change IP address range values in LAN DHCP setting
I am using MR60 router. I cant change DHCP range in LAN setting from admin console. As soon as I change ending IP address (last four digits) from 10.0.0.254 to 10.0.0.250 and click Apply, the router ...
vish_at
Feb 09, 2026Aspirant
Nothing is changed. I posted the screenshot without any change. 10.0.0.2 to 10.0.0.254. I wanted to change the IP range, so that I can have an IP outside of the DHCP range which I can use to reserve as static IP, but none of the changes gets retained. As soon as I click 'Apply' after making any changes, router restarts and settings get reset to original.
- FURRYe38Feb 09, 2026Guru - Experienced User
What browser are you using on the MRs web page to make changes?
And you did a factory reset and setup from scratch with a ethernet connected PC and web browser and tried to make this changes with out the MR connected to anything accept for the one PC?
What FW version is on the MR and MS?
- coolwifiFeb 09, 2026Virtuoso
What happens if you set a static IP in the pihole?
