vish_at
Feb 03, 2026Aspirant
cant change IP address range values in LAN DHCP setting
I am using MR60 router. I cant change DHCP range in LAN setting from admin console. As soon as I change ending IP address (last four digits) from 10.0.0.254 to 10.0.0.250 and click Apply, the router ...
vish_at
Feb 09, 2026Aspirant
Nothing is changed. I posted the screenshot without any change. 10.0.0.2 to 10.0.0.254. I wanted to change the IP range, so that I can have an IP outside of the DHCP range which I can use to reserve as static IP, but none of the changes gets retained. As soon as I click 'Apply' after making any changes, router restarts and settings get reset to original.
coolwifi
Feb 09, 2026Virtuoso
What happens if you set a static IP in the pihole?
