vish_at
Feb 03, 2026Aspirant
cant change IP address range values in LAN DHCP setting
I am using MR60 router. I cant change DHCP range in LAN setting from admin console. As soon as I change ending IP address (last four digits) from 10.0.0.254 to 10.0.0.250 and click Apply, the router ...
CrimpOn
Feb 09, 2026Guru - Experienced User
vish_at wrote:Nothing is changed. I posted the screenshot without any change. 10.0.0.2 to 10.0.0.254
Something about this seems "odd". My Netgear router definitely displays both starting and ending IPs in regular text:
It is always a good idea to verify that the router is running the current firmware release.
For the MR60 that is v1.1.8.142, released in October, 2025.
- coolwifiFeb 09, 2026Virtuoso
The IP address range gets displayed the same as OP in my RS500 router too, that doesn't sound like an issue though.
- StephenBFeb 09, 2026Guru - Experienced User
What seems odd to you???
My Orbi also has the first three fields in the DHCP range grayed out (my subnet mask is also 255.255.255.0).
The router IP address (which is what you seem to be showing) allows all four fields to be edited.
I agree.
