vish_at
Feb 03, 2026Aspirant
cant change IP address range values in LAN DHCP setting
I am using MR60 router. I cant change DHCP range in LAN setting from admin console. As soon as I change ending IP address (last four digits) from 10.0.0.254 to 10.0.0.250 and click Apply, the router ...
CrimpOn
Feb 09, 2026Guru - Experienced User
Thanks to everyone for checking. Yes, my Orbi RBR50 and RBR750 both show the first three octets of the DHCP range "greyed out" and cannot be changed.
They paste into a Forum message like this:
Since FURRYe38 was able to change the DHCP range on his MR60 with firmware 1.1.7.134, and the OP's MR60 is also running 1.1.7.134, this appears to a case for the dreaded Factory Reset.
(I saw someone asked if that was done, but am not finding the response.)
The first 3 octets can't be changed as only the 4th one can be. Can only effect the 1st 3 octets by changing the router IP address.
