vish_at
Feb 03, 2026Aspirant
cant change IP address range values in LAN DHCP setting
I am using MR60 router. I cant change DHCP range in LAN setting from admin console. As soon as I change ending IP address (last four digits) from 10.0.0.254 to 10.0.0.250 and click Apply, the router ...
vish_at
Feb 10, 2026Aspirant
I downloaded latest firmware release v1.1.8.142 and manually updated it.. Still not able to change the range, but I am able to add static IP within the DHCP range. I will use 10.0.0.252 as static IP for Pi-hole for now. Hopefully, won't see any conflict.
Feb 10, 2026Guru - Experienced User
vish_at wrote:I downloaded latest firmware release v1.1.8.142 and manually updated it.
Still suggest trying a factory reset.
Or reserve the IP address in the router.
