acayci
Nov 21, 2025Tutor
Connecting a Jetson Orin Nano to a Nighthawk MR60 and Enabling Secure Remote Access
Hello, I’m using a Netgear Nighthawk MR60. I purchased a Jetson Orin Nano, which is essentially a powerful computer with an Ethernet port. Since the MR60 has only one Ethernet port, I don’t have ...
Nov 21, 2025Guru - Experienced User
Get you one of these:
https://www.netgear.com/support/product/gs305v2
GS10# series will work too.
They also come in 8 or 16 port versions as well.
Contact the Mfr of the Nano device for help and support information regarding there product.
