acayci
Nov 21, 2025Tutor
Connecting a Jetson Orin Nano to a Nighthawk MR60 and Enabling Secure Remote Access
Hello, I’m using a Netgear Nighthawk MR60. I purchased a Jetson Orin Nano, which is essentially a powerful computer with an Ethernet port. Since the MR60 has only one Ethernet port, I don’t have ...
acayci
Nov 21, 2025Tutor
Hello FURRYe38 Thanks a lot for your reply. I also see Multi-Gigabit Ethernet Easy Smart Managed Essentials Switch (MS305E). It is more expensive compared to GS305v2. Which one should I go with?
Mustafa
- FURRYe38Nov 21, 2025Guru - Experienced User
Go with the non managed. You don't need anything managed/Smart on the switch.
Just need additional LAN ports to add which the MR didn't come with. The non managed switch will add that for you.
Mustafa
